[postgis-users] Installation with Proj
Rob Agar
robagar at westnet.com.au
Mon Jun 4 05:09:21 PDT 2007
Andy Dale wrote:
> NOTICE: type "histogram2d" is not yet defined
that one rings a bell too - in this case, I think I had forgotten to
actually run "make install"...
btw, does the file /usr/lib/pgsql/liblwgeom.so.1.2 actually exist? If
so you might want to check the postgres lib directory by running
pg_config --libdir, which will tell you where postgres looks for library
files
On my system where everything was installed to wherever the vanilla
.configure scripts chose to put them, the liblwgeom.* files are all in
/usr/local/pgsql/lib (which is where postgres is expecting them,
according to pg_config --libdir)
Rob
