[postgis-users] Installation with Proj
Antonio Jorge Silva
antonio.silva at igeo.pt
Mon Jun 4 03:36:39 PDT 2007
Hi Andy
I am a newbie on PostGIS, but it seems to me that you don't have GEOS
installed... Maybe liblwgeom.so.1.2 is a library somehow related with
GEOS...
Could this be the problem?
Best regards,
António
Andy Dale wrote:
> Hi,
> I managed to install and use
> Postgis without any problems, but later found out that i could not do any reprojections without the proj library.
> I downloaded and installed the proj library. I then attempted to re-install Postgis with proj support like so:
> ./configure --with-proj=yes (without specifying this flag it still find
> the proj library) It produces the following output:
> SUMMARY
> HOST_OS: linux-gnu
> PGSQL: /usr/bin/pg_config
> PROJ: prefix=/usr/local libdir=/usr/local/lib
> ICONV: 1
> PORTNAME: linux
> PREFIX: /usr
> EPREFIX: ${prefix}
> DOC: /usr/share/doc/postgresql/contrib
> DATA: ${datarootdir}
> MAN: ${datarootdir}/man
> BIN: /usr/bin
> EXT: /usr/lib/pgsql (\$$libdir)
> Now when i try to run either the lwpostgis_upgrade.sql or lwpostgis.sql
> (creates histogram2d then fails) i get the following error
> ERROR: could not load library "/usr/lib/pgsql/liblwgeom.so.1.2":
> libproj.so.0: cannot open shared object file: No such file or directory
> Can anyone tell me where i have gone wrong in the installation ??
> Thanks in advance,
> Andy
> postgis-users mailing list
António Jorge Silva
Instituto Geográfico Português
Rua Artilharia Um, 107
1099-052 LISBOA
PORTUGAL
Tel: (351) 213819600
Ext: 334
Email: antonio.silva at igeo.pt
