[postgis-users] compiling problems - requires PostgreSQL, but it is installed
ValiSystem
vali.system at free.fr
Mon Jun 4 09:00:03 PDT 2007
On 4 juin 07, at 15:53, Kenton Williams wrote:
> Hello,
> I'm trying to compile PostGIS on PCLinuxOS. I have successfully
> compiled and installed PostgreSQL and it is operating fine. I have
> obtained the PostGIS source and followed the instructions untarring
> it into the PostgreSQL source code /contrib directory, but I cannot
> even get ./configure to complete. I get the error message stating
> that PostgreSQL is required.
> I'm a little new to all this, so perhaps someone could advise me on
> what I'm doing wrong? It would seem that the PDF documentation may
> be a little older than the versions of PostgreSQL and PostGIS that
> are available. Thanks in advance!
> Kenton Williams
> GIS Analyst
> Penobscot Bay Media
> 32 Washington St., Suite 230
> Camden, ME 04843
> http://www.penbaymedia.com
Since you compiled PostgreSQL yourself, i assume that you did not
used standard paths for installation (which is generally a good idea,
because it helps to keep track of your custom installations).
PostGIS searches for a postgresql tool called pg_config, which is
located in the bin directory of your postgresql target installation
path. If pg_config cannot be found in the standard path (eg typing
'pg_config' in a terminal returns "command not found"), then postgis
will complain that postgresql cannot be found.
Hopefully the ./configure script (and that is a standard behavior you
can find for other source trees) enables you to specify the pg_config
full path.
take a look at './configure --help'
you will get in the options list these lines :
--with-pgsql[=ARG] build for a specific pgsql version
[ARG=path to pg_config]
bingo !
try './configure --with-pgsql=/your/path/to/pg_config' and it should
not complain about a missing PosgreSQL.
Note that you have the same behavior for geos.
Please note that it is a really common way of doing things, here you
specify the path for a tool, but you also might have to define
includes and libraries paths.
Regards.
