[postgis-users] Trying to figure out topology
William Kyngesburye
woklist at kyngchaos.com
Tue Jun 5 10:38:17 PDT 2007
I'm trying to figure out the topology functions in postgis - a little
experimentation to see what's there, hoping to possibly use node data
for pgrouting functions. I want to generate topology for a line
The wiki is a little technical right now with no real examples, but I
got this far in setting up topology (working with the pgrouting
sample data, 'kanagawa' roads):
- load the topology.sql to create the 'topology' schema.
- select topology.CreateTopology('kanagawa', 4326);
(I imported with GDAL and set the srid to 4326 instead of -1 you get
with shp2psql)
- select topology.AddTopoGeometryColumn('kanagawa', 'public',
'kanagawa', 'topology', 'LINE');
- select topology.CreateTopoGeom('kanagawa', 'LINE', 2);
Now I get to generating topology for each line in the layer. The
wiki has:
select topology.CreateTopoGeom(topology_name, feature_type, layer_id
[as returned from AddTopoGeometryColumn], TopoElementArray);
but the link to TopoElementArray doesn't really tell me where to get
those element type/element id pairs for the array. Would those be
the geom types and feature IDs of the layer? Would I use a SQL
select to pipe in all the rows of the layer? Examples would be much
appreciated.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
