[postgis-users] unable to install PostGIS -1.2.1 on Ubuntu Feisty Fawn version
TECHER David
davidtecher at yahoo.fr
Tue Jun 5 18:17:58 PDT 2007
Hi Tahir
the postgis wiki about ubuntu is old
If the following command
apt-cache show libgeos-dev|grep Version
send you something like 2.1.4.2 < 2.2.X
You should install geos using the source
First remove geos i.e libgeos or libgeos-dev
Since you understand french..
then have a look here
http://www.davidgis.fr/documentation/win32/html/ch03.html
--david;
Tahir Tamba a écrit :
> Dear list,
> I'm a newbie in Gnu/Linux Ubuntu 7.04 and I'm trying to install
> PostGIS latest version using the following steps described on the How
> To PostGIS Wiki for Ubuntu users. I've already installed PosgreSQL
> 8.2.3 and it works fine but when I start compiling, configuring and
> installing the new version's Libgeos and Proj packages, after a while
> a get a error at the end of the process.
> Also, I try to installing PostGIS directly using the former version of
> Libgeos and Proj provided on Ubuntu distribution via Synaptec Manager,
> but unable to past the downloaded PostGIS 1.2.3.tar after copying it
> on the postgresql directory in: usr/share/postgresql/8.2.3/contrib as
> specified in the PostGIS How Install PostGIS on Ubuntu.
> Any help , suggestion about this issue wuold very appreciated...
> Cheers
> Tahir Tamba
> MSc. Géographie
> Aménagement du territoire et SIG/ Gestion et conservation des
> ressources naturelles
> Télédétection-cartographie écologique, caractérisation des milieux
> humides
> Tel: (514) 526-7543
> Courriel: tamba.tahir at courrier.uqam.ca
> Tahir Tamba
> MSc. Geography
> Urban planning and GIS specialist/Natural resources management and
> conservation
> Remote-sensing-ecological mapping and wetland monitoring and
> Characterization
> Tel: (514) 526-7543
> E-mail: tamba.tahir at courrier.uqam.ca
> postgis-users mailing list
___________________________________________________________________________
Yahoo! Mail réinvente le mail ! Découvrez le nouveau Yahoo! Mail et son interface révolutionnaire.
http://fr.mail.yahoo.com
