[postgis-users] Slow select from big table
volunteer at spatiallink.org volunteer at spatiallink.org
Wed Jun 6 08:51:58 PDT 2007
what if
select count(*) from table where true;
sincerely
siva
-------- Original Message --------
Subject: RE: [postgis-users] Slow select from big table
From: "Matt Doughty" <matt.doughty at geograma.com>
Date: Wed, June 06, 2007 11:30 am
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
I'm trying out a vacuum at the moment to see if it helps.       Matt
           Matt Doughty     GEOGRAMA S.L.   Tel.:  +34 945 13 13 72
652 77 14 15   Fax: +34 945 23 03 40    www.geograma.com
De: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] En nombre de Rob
Tester
Enviado el: miércoles, 06 de junio de 2007 17:23
Para: 'PostGIS Users Discussion'
Asunto: RE: [postgis-users] Slow select from big table
Sounds more like a question for the general group.  But, have you run a
vacuum analyze on the table ?
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Matt Doughty
Sent: Wednesday, June 06, 2007 8:19 AM
To: postgis-users at postgis.refractions.net
Cc: Sergio Jorrín Abellán
Subject: [postgis-users] Slow select from big table
Hi List,   I've got a simple question, how can I speed up this query?
SELECT COUNT (*) FROM table1   Currently it's taking a little more than
five minutes to run on a table with 3.4 m rows. The table is gist
indexed. Is it normal that Postgres takes so long?   Cheers,   Matt
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070606/98dedbc9/attachment.jpg>
