[postgis-users] Slow select from big table
Gerry Creager
gerry.creager at tamu.edu
Wed Jun 6 08:53:54 PDT 2007
What version of the database code are you running?
volunteer at spatiallink.org wrote:
> what if
> select count(*) from table where true;
> sincerely
> siva
> -------- Original Message --------
> Subject: RE: [postgis-users] Slow select from big table
> From: "Matt Doughty" <matt.doughty at geograma.com>
> Date: Wed, June 06, 2007 11:30 am
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> I'm trying out a vacuum at the moment to see if it helps. Matt
> Matt Doughty GEOGRAMA S.L. Tel.: +34 945 13 13 72
> 652 77 14 15 Fax: +34 945 23 03 40 www.geograma.com
> De: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] En nombre de Rob
> Tester
> Enviado el: miércoles, 06 de junio de 2007 17:23
> Para: 'PostGIS Users Discussion'
> Asunto: RE: [postgis-users] Slow select from big table
> Sounds more like a question for the general group. But, have you run a
> vacuum analyze on the table ?
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Matt Doughty
> Sent: Wednesday, June 06, 2007 8:19 AM
> To: postgis-users at postgis.refractions.net
> Cc: Sergio Jorrín Abellán
> Subject: [postgis-users] Slow select from big table
> Hi List, I've got a simple question, how can I speed up this query?
> SELECT COUNT (*) FROM table1 Currently it's taking a little more than
> five minutes to run on a table with 3.4 m rows. The table is gist
> indexed. Is it normal that Postgres takes so long? Cheers, Matt
> postgis-users mailing list
Gerry Creager -- gerry.creager at tamu.edu
Texas Mesonet -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.862.3983
Office: 1700 Research Parkway Ste 160, TAMU, College Station, TX 77843
