[postgis-users] Question about Crosses(geometry, geometry)
Matt Doughty matt.doughty at geograma.com
Fri Jun 8 03:30:10 PDT 2007
David,
Thanks for the tip but it didn't work. It returned the following error:
>ERROR: missing FROM-clause entry for table "polygons"
Matt
Matt Doughty
GEOGRAMA S.L.
Tel.:  +34 945 13 13 72    652 77 14 15
Fax: +34 945 23 03 40
www.geograma.com
-----Mensaje original-----
De: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] En nombre de TECHER David
Enviado el: viernes, 08 de junio de 2007 12:27
Para: PostGIS Users Discussion
Asunto: Re: [postgis-users] Question about Crosses(geometry, geometry)
Hi Matt
instead of
select lines.* from lines,polygons where not
crosses(lines.the_geom,polygons.the_geom)
try
select lines.* from lines where not
don't use a call to polygons' table
Matt Doughty a écrit :
> Hi List,
> I've a question about the CROSSES (geometry, geometry) function. I'd
> like to use it to select lines from a table that do not cross, or
> intersect, some polygons in a separate table.
> The following script lets me select the lines that cross the polygons:
> SELECT
> lines.*
> FROM
> lines,
> polygons
> WHERE
> CROSSES(lines.the_geom, polygons.the_geom)
> Now I'd like to place a 'NOT' before the function CROSSES (-> NOT
> CROSSES(lines.the_geom, polygons.the_geom), rather naively it seems,
> as doing that returns me a table with the same geometry as the
> original layer, but with 30 times more rows (an increase of 400 to
> 12,000 records). In other words, it hasn't 'selected' and lines out of
> the layer, merely repeated the table geometry 30 times.
> Can anybody explain where I'm going wrong?
> Many thanks in advance,
> Matt
> Matt Doughty
> GEOGRAMA S.L.
> www.geograma.com <http://www.geograma.com/>
> postgis-users mailing list
___________________________________________________________________________
Yahoo! Mail réinvente le mail ! Découvrez le nouveau Yahoo! Mail et son interface révolutionnaire.
http://fr.mail.yahoo.com
