[postgis-users] Question about Crosses(geometry, geometry)
Obe, Regina
robe.dnd at cityofboston.gov
Fri Jun 8 03:52:32 PDT 2007
There are 3 ways of doing it I can think of. I'm assuming you are trying to figure out which lines do not cross any of the polygons correct?
I'm not sure which would be faster in your case. Way 1 is usually the fastest
Way 1
SELECT lines.*
FROM lines LEFT JOIN polygons ON crosses(lines.the_geom,polygons.the_geom)
WHERE polygons.the_geom is NULL
Way 2 - I think what David was thinking (here I am assuming gid is primary key of your lines table) - non-correlated subquery
SELECT lines.*
FROM lines
WHERE lines.gid NOT IN(SELECT l.gid FROM lines l, polygons p WHERE crosses(l.the_geom,polygons.the_geom))
Way 3 - correlated subquery
SELECT lines.*
FROM lines
WHERE NOT EXISTS(SELECT p.the_geom FROM polygons p WHERE crosses(lines.the_geom,polygons.the_geom))
Hope that hleps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Matt Doughty
Sent: Friday, June 08, 2007 6:30 AM
To: davidtecher at yahoo.fr; PostGIS Users Discussion
Subject: RE: [postgis-users] Question about Crosses(geometry, geometry)
David,
Thanks for the tip but it didn't work. It returned the following error:
>ERROR: missing FROM-clause entry for table "polygons"
Matt
Matt Doughty
GEOGRAMA S.L.
Tel.: +34 945 13 13 72 652 77 14 15
Fax: +34 945 23 03 40
www.geograma.com
-----Mensaje original-----
De: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] En nombre de TECHER David
Enviado el: viernes, 08 de junio de 2007 12:27
Para: PostGIS Users Discussion
Asunto: Re: [postgis-users] Question about Crosses(geometry, geometry)
Hi Matt
instead of
select lines.* from lines,polygons where not
try
select lines.* from lines where not
don't use a call to polygons' table
Matt Doughty a écrit :
> Hi List,
> I've a question about the CROSSES (geometry, geometry) function. I'd
> like to use it to select lines from a table that do not cross, or
> intersect, some polygons in a separate table.
> The following script lets me select the lines that cross the polygons:
> SELECT
> lines.*
> FROM
> lines,
> polygons
> WHERE
> CROSSES(lines.the_geom, polygons.the_geom)
> Now I'd like to place a 'NOT' before the function CROSSES (-> NOT
> CROSSES(lines.the_geom, polygons.the_geom), rather naively it seems,
> as doing that returns me a table with the same geometry as the
> original layer, but with 30 times more rows (an increase of 400 to
> 12,000 records). In other words, it hasn't 'selected' and lines out of
> the layer, merely repeated the table geometry 30 times.
> Can anybody explain where I'm going wrong?
> Many thanks in advance,
> Matt
> Matt Doughty
> GEOGRAMA S.L.
> www.geograma.com <http://www.geograma.com/>
> postgis-users mailing list
___________________________________________________________________________
Yahoo! Mail réinvente le mail ! Découvrez le nouveau Yahoo! Mail et son interface révolutionnaire.
http://fr.mail.yahoo.com
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
