[postgis-users] Insert transformed coordinates
Charlton Purvis
cplist at secondcreek.org
Fri Jun 8 14:43:22 PDT 2007
Gary,
> SELECT INTO transCoord X(SubSel.transformed_geom),
> Y(SubSel.transformed_geom) FROM (
That part of the select into looks suspicious to me. Have you tried
selecting into plain variables?
declare
my_x float;
my_y float;
select into my_x, my_y X(SubSel.transformed_geom),
SELECT SetSRID(
INSERT INTO
vts_route_stops(stop_number,stop_description,stop_latitude,stop_longitude)
VALUES(stopnum,stopdes,my_y,my_x);
I think that will work. I might be off in the syntax above, but what looks
weird is the way you're selecting into components of a record set.
Charlton
