[postgis-users] Insert transformed coordinates
Gary Townsend garyt at spatialmapping.com
Fri Jun 8 14:20:58 PDT 2007
Sorry bout the no subject
  _____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Gary
Townsend
Sent: June 8, 2007 2:17 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] (no subject)
Below is a function I am trying to create that will take a series of
geographic points form a UTM projection and translate it to lat/long that's
not the problem though the translation works wonderfully as a separate
select statement. I'm trying to encapsulate this into a function now and I
am getting a problem returned saying:
ERROR: syntax error at or near "$2"
SQL state: 42601
Character: 137
Context: PL/pgSQL function "vts_insert_stop" line 10 at select into
variables
I'm not sure where I've gone sideways on this but seeing as how I'm still
learning the pgplsql syntax I figured it could be anywhere I thought maybe
someone here may have a better soloution to what I'm trying to do or can see
what I'm doin wrong.
CREATE OR REPLACE FUNCTION vts_insert_stop(text, text, numeric, numeric,
numeric)
  RETURNS numeric AS
DECLARE
      stopnum ALIAS for $1;
      stopdes ALIAS for $2;
      stopeasting ALIAS for $3;
      stopnorthing ALIAS for $4;
      projection ALIAS for $5;
      transCoord RECORD;
BEGIN
      SELECT INTO transCoord X(SubSel.transformed_geom),
Y(SubSel.transformed_geom) FROM (
        SELECT SetSRID(
          Transform(
            GeomFromText(
            ''POINT('' || stopeasting || '' '' stopnorthing || '')'',
projection
            ), 4326
        -1) AS transformed_geom) SubSel;
      INSERT INTO
vts_route_stops(stop_number,stop_description,stop_latitude,stop_longitude)
      VALUES(stopnum,stopdes,transCoord.Y,transCoord.X);
      RERTURN void;
END'
  LANGUAGE 'plpgsql' VOLATILE;
Gary Townsend (Systems Programmer & Developer )
Spatial Mapping Ltd.
#200 484 2nd Ave. Prince George, B.C., Canada V2L 2Z7
Phone: 250 564 1928
Fax: 250 564 0751
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070608/98558648/attachment.html>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070608/98558648/attachment.gif>
