[postgis-users] (no subject)
Gary Townsend
garyt at spatialmapping.com
Fri Jun 8 14:16:59 PDT 2007
Below is a function I am trying to create that will take a series of
geographic points form a UTM projection and translate it to lat/long that's
not the problem though the translation works wonderfully as a separate
select statement. I'm trying to encapsulate this into a function now and I
am getting a problem returned saying:
ERROR: syntax error at or near "$2"
SQL state: 42601
Character: 137
Context: PL/pgSQL function "vts_insert_stop" line 10 at select into
variables
I'm not sure where I've gone sideways on this but seeing as how I'm still
learning the pgplsql syntax I figured it could be anywhere I thought maybe
someone here may have a better soloution to what I'm trying to do or can see
what I'm doin wrong.
CREATE OR REPLACE FUNCTION vts_insert_stop(text, text, numeric, numeric,
numeric)
RETURNS numeric AS
DECLARE
stopnum ALIAS for $1;
stopdes ALIAS for $2;
stopeasting ALIAS for $3;
stopnorthing ALIAS for $4;
projection ALIAS for $5;
transCoord RECORD;
BEGIN
SELECT INTO transCoord X(SubSel.transformed_geom),
Y(SubSel.transformed_geom) FROM (
SELECT SetSRID(
Transform(
GeomFromText(
''POINT('' || stopeasting || '' '' stopnorthing || '')'',
projection
), 4326
-1) AS transformed_geom) SubSel;
INSERT INTO
vts_route_stops(stop_number,stop_description,stop_latitude,stop_longitude)
VALUES(stopnum,stopdes,transCoord.Y,transCoord.X);
RERTURN void;
END'
LANGUAGE 'plpgsql' VOLATILE;
Gary Townsend (Systems Programmer & Developer )
Spatial Mapping Ltd.
#200 484 2nd Ave. Prince George, B.C., Canada V2L 2Z7
Phone: 250 564 1928
Fax: 250 564 0751
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070608/40dccc3a/attachment.html>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070608/40dccc3a/attachment.gif>
