[postgis-users] Mapguide and PostGis - Using Filters
Paul Ramsey
pramsey at refractions.net
Fri Jun 8 10:30:29 PDT 2007
Might not be implemented yet? Or a version issue. Are you using the
fdopostgis driver? Or the OGR driver? Or the ODBC driver?
On 8-Jun-07, at 10:18 AM, Scott, Brian wrote:
> Hello friends -
> We have an Enterprise MapGuide installation up and running on top
> of a Postgres database. However, we really need to apply filters
> to layers; and nothing we try seems to work. From within the
> Mapguide environment if we ask it to apply a filter to the layer,
> we get no points back. We have confidence that the data contains
> points that match the criteria. If we remove the filter, the
> entire layer shows up fine. We get identical behavior attempting
> to create layers on the fly via php API calls. The layer does get
> created, but applying any filter causes it to return no points.
> Null out the filter definition, and the enire layer returns.
> Has anyone out there succesfully applied a filter to Postgis data
> using the Mapguide product? If so, can you let me in on the
> secret? Any insight is appreciated!
> brian
> postgis-users mailing list
