[postgis-users] performance problem with loading data
Sergey Karin
sergey.karin at gmail.com
Sat Jun 9 01:48:03 PDT 2007
Hi all.
I use PG 8.1.8 and PostGIS 1.1.1
vka1=# select version();
version
PostgreSQL 8.1.8 on x86_64-pc-linux-gnu, compiled by GCC cc (GCC)
4.1.220061115 (prerelease) (Debian
4.1.1-21)
vka1=# select postgis_full_version();
POSTGIS="1.1.1" GEOS="2.2.3-CAPI-1.1.1" PROJ="Rel. 4.4.9, 29 Oct 2004"
USE_STATS
I develop application for loading geodata to database. In separate
transaction the application inserts the data in separate table that created
dynamically when transaction started. All tables has equal structure.
Geodata has simple and similar structure (field geometry): POLYGON((x1 y1,
x2 y2, x3 y3, x4 y4, x1 y1))
For loading geodata I use INSERT into <TABLE_NAME> .... via LIBPQ.
In big loop I call PQexec(conn, query).
I found *VERY* strange problem: speed of the loading process is slow down
(first 10000 objects are loaded in 69792 ms and last 10000 objects in 123737
ms). And futhermore, if I do NOT close current session but start new
transaction, the first 10000 objects will be loaded in 192279 ms and last
10000 objects in 251742 ms. And so on!! :-(
But if I drop the trigger speed of loading process is NOT slow down.
Who can explain me what I do incorrect?
Thanks in advance
Sergey Karin
================code===================
create table <TABLE_NAME> (
GID SERIAL not null,
GEOM_ORDER INT4 not null default 0,
ZOOMABLE BOOL not null default false,
GEOM GEOMETRY
constraint <TABLE_NAME_GID> primary key (GID),
create index <TABLE_NAME_GEOM_INDEX> on <TABLE_NAME> using gist ( geom
gist_geometry_ops );
create trigger trgOInsert
before insert or update
on <TABLE_NAME>
for each row
execute procedure oInsertCheck('GEOMETRYCOLLECTION', 0);
create or replace function oInsertCheck() returns trigger as'
declare
g_isvalid boolean;
iSrid int4;
geomType varchar;
begin
if(new.geom isnull) then
new.geom := geomFromText(\'GEOMETRYCOLLECTION(EMPTY)\');
end if;
if(new.geom_order isnull) then
new.geom_order := 0;
end if;
select isvalid(new.geom) into g_isvalid;
if(g_isvalid isnull) then
return NULL;
end if;
geomType := TG_ARGV[TG_NARGS-2];
iSrid := TG_ARGV[TG_NARGS-1];
if(upper(geomType) = \'GEOMETRYCOLLECTION\') then
new.geom := force_collection(new.geom);
end if;
new.geom := setSrid(new.geom, iSrid);
return new;
end
'language 'plpgsql' security definer;
=================end of code==========================
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070609/2489e167/attachment.html>
