[postgis-users] Shapefile toolkit
Steffen Macke
sdteffen at gmail.com
Sat Jun 9 13:18:46 PDT 2007
Hi David,
> Is anybody aware of any tools to creat or manipulate shape files?
> I have a shape file and I want to add some projection data to it
a little bit off-topic, but here is some information:
Adding projection information to a shapefile can be as simple as copying
a file (*.prj). But it might also be difficult, if you don't have a
"template" containing
your projection information. It will be quite important which software package
you expect to use your shapefile projection data.
OGR comes with a collection of tools that allow some manipulation of shapefiles.
http://www.gdal.org/ogr/
Shapelib comes with a collection of tools that allow some manipulation. If you
want to reproject your shapefile, have a look at the shpproj tool that
is included
in Shapelib.
http://shapelib.maptools.org/
These are commandline tools. If you are looking for graphical interfaces, there
might be other options.
Regards,
Steffen
