[postgis-users] Shapefile toolkit
Stephen Woodbridge
woodbri at swoodbridge.com
Sat Jun 9 13:25:02 PDT 2007
Dave Potts wrote:
> Is anybody aware of any tools to creat or manipulate shape files?
> I have a shape file and I want to add some projection data to it
PostGIS is a good tool for this. Or if you are C language compatible you
can get shapelib and write trivial tools for manipulating them. I do
this all the time.
Question: what do you mean by: "add some projection data to it"?
Shapefiles per say do not have projection information. ESRI Arc* tools,
the newer ones anyway, create file.prj file but shapefiles themselves
have no projection definition.
If on the other hand you have data that is in a different project and
you would like to merge is with data from a different projection, then
why not load it into postgis and multiple tables using shp2pgsql where
each table has the appropriate srid set. Then do something like:
insert into tablea (select col1, col2, transform(the_geom, srid_from
tablea) from tableb);
This will transform the data from tableb srid to tablea srid and insert
it into tablea
then you can use pgsql2shp to dump the data back out to a shapefile.
-Steve
