[postgis-users] Shapefile toolkit
Dave Potts
dave.potts at pinan.co.uk
Sat Jun 9 13:34:15 PDT 2007
Stephen Woodbridge wrote:
> Dave Potts wrote:
>> Is anybody aware of any tools to creat or manipulate shape files?
>> I have a shape file and I want to add some projection data to it
> PostGIS is a good tool for this. Or if you are C language compatible
> you can get shapelib and write trivial tools for manipulating them. I
> do this all the time.
> Question: what do you mean by: "add some projection data to it"?
Good question, I have the .shp, .dbx and .shx files, but no .prj files.
Thanks for the tips.
Dave.
> Shapefiles per say do not have projection information. ESRI Arc*
> tools, the newer ones anyway, create file.prj file but shapefiles
> themselves have no projection definition.
> If on the other hand you have data that is in a different project and
> you would like to merge is with data from a different projection, then
> why not load it into postgis and multiple tables using shp2pgsql where
> each table has the appropriate srid set. Then do something like:
> insert into tablea (select col1, col2, transform(the_geom, srid_from
> tablea) from tableb);
> This will transform the data from tableb srid to tablea srid and
> insert it into tablea
> then you can use pgsql2shp to dump the data back out to a shapefile.
> -Steve
> postgis-users mailing list
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070609/59e963dd/attachment.vcf>
