[postgis-users] How is Centroid(Geometry) calculated?
Matt Doughty
matt.doughty at geograma.com
Thu Jun 14 08:24:44 PDT 2007
Thanks for explaining all this. I think it's an interesting debate that
is often overlooked in these cases. I think the pointonsurface()
function was what I was looking for this time.
Matt
Matt Doughty
GEOGRAMA S.L.
Tel.: +34 945 13 13 72 652 77 14 15
Fax: +34 945 23 03 40
www.geograma.com
De: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] En nombre de Obe,
Regina
Enviado el: jueves, 14 de junio de 2007 13:52
Para: PostGIS Users Discussion
Asunto: RE: [postgis-users] How is Centroid(Geometry) calculated?
It uses the Geos library to calculate centroid if Geos is installed. My
cursory glance of the Geos code, looks to me like for polygons and
multipolygons
it first takes the area of the region and then finds the average x,y, z
of that encompassing area.
So yes it is conceivable in a multipolygon that the centroid may not
fall in any of the polygons.
Anyone correct me if I am wrong since I'm not too familiar with c++
code.
Anyrate I think the relevant piece of code in geos library is
source\algorithm\CentroidArea.cpp
Hope that helps,
Regina
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Matt
Doughty
Sent: Thursday, June 14, 2007 7:03 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] How is Centroid(Geometry) calculated?
Can anybody explain how PostGIS calculates centroids? I've checked the
manual but the relevant section doesn't refer to an OGC Specification.
>From what I can understand, it takes an average of the coordinates of
all the vertices of an entry, ignoring whether or not the centroid falls
outside the polygons. Is this right? This differs from other GIS-
GeoMedia, for example, when confronted with a multipolygon entry, always
puts the centroid inside the largest polygon.
Can anybody shed some light on this?
Cheers,
Matt
Matt Doughty
GEOGRAMA S.L.
www.geograma.com
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure pursuant
to Massachusetts law. It is intended solely for the addressee. If you
received this in error, please contact the sender and delete the
material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070614/525dc1d7/attachment.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070614/525dc1d7/attachment.jpg>
