[postgis-users] Problems with making own shape dumper
Mark Cave-Ayland
mark.cave-ayland at ilande.co.uk
Thu Jun 14 14:55:50 PDT 2007
On Thu, 2007-06-14 at 23:34 +0300, Дорофеев А.В. wrote:
> At first I wanted to create own
> but I met issue with ASTEXT() function that returned a broken string in some
> multipolygons. I can`t understand where is a bug .ASTEXT(the_geom) returned
> normal string. But when I`m trying to set this value to some field or
> dump it into some variable ,the string became broken.
> The dicussion of this bug
> http://postgis.refractions.net/bugs/bug.php?op=show&bugid=151
(cut)
> "What is the reason of ASTEXT() function issue? and what to do to fix it?"
Please send us an exact set of instructions to replicate the problem
from an empty PostGIS database, including any CREATE TABLE statements.
This should be a text file that we can simply cut and paste into psql.
If we can recreate it, we can fix it.
Kind regards,
Mark.
ILande - Open Source Consultancy
http://www.ilande.co.uk
