[postgis-users] re:Problems with making own shape dumper
Mark Cave-Ayland
mark.cave-ayland at ilande.co.uk
Fri Jun 15 03:01:06 PDT 2007
On Fri, 2007-06-15 at 13:31 +0400, дорофеев александр wrote:
> I took this shapefile (Arc) and uploaded it into postgis using standart shp2pgsql
> Then I tryed to download this data into shapefile using my own dumper and I`ve got an error with spliting string on feature with FID=7. Then i dumped this geometry string into textfile and got this (brokenstring.txt)
> then i made biggeom.sql and run it in psql to see if a string will be broken and all was fine
> The Developers said than it is a bug of ODBC driver. I checked this sugggestion by addind text field to postgis table and run such sql UPDATE testtable SET testfield=ASTEXT(the_geom) and the string in this field became broken (maybe not finished) on small objects the value of this field looked well
Ok I've just done a test here on Linux and did the following:
shp2pgsql arc testtable -W LATIN1 > arc.sql
psql -d postgis -f arc.sql
Followed by:
SELECT astext(the_geom) FROM testtable where gid = 7;
SELECT astext(the_geom) FROM testtable;
(Both of these look fine)
Then:
ALTER TABLE testtable ADD COLUMN testfield text;
UPDATE testtable SET testfield = astext(the_geom);
SELECT testfield FROM testtable;
Everything looks fine here. Can you confirm that these steps give you
the problem? Also, which versions of PostGIS/PostgreSQL are you using?
Please send the output of:
SELECT version();
SELECT postgis_full_version();
Kind regards,
Mark.
ILande - Open Source Consultancy
http://www.ilande.co.uk
