[postgis-users] Combined Windows version of PostGIS/P-LR
Mike Leahy
mgleahy at alumni.uwaterloo.ca
Tue Jun 19 06:42:41 PDT 2007
Regina,
I'm copying this to the plr-general list (plr-general at pgfoundry.org).
I can't say that I'm getting the same error. I've installed the version
from David's installer, and I did the exact same example from the PL/R
docs that you're trying and it's working for me too. Maybe there's an
encoding problem in your case?
Mike
Obe, Regina wrote:
> Unfortunately I'm not in the PL/R newsgroup yet and I don't have Joe's email address, so can someone pass this message along. I'm updating my instruction docs accordingly to reflect this issue and still writing up some followup tutorials.
> When testing creating the median function as described in the docs using PgAdmin, I would get parse R errors when using it. After some research (googling - others had the same problem) and refollowing my tracks (since I was able to get it right a couple of times, but not consistently). I discovered it was the line breaks in the function that was causing the problem.
> I had to do this
> create or replace function r_median(_float8)
> returns float as 'median(arg1)' language 'plr';
> instead of what is mentioned in the docs - this
> create or replace function r_median(_float8) returns float as '
> median(arg1)
> ' language 'plr';
> Evidentally R parser chokes when it runs into line breaks.
> Hope that helps,
> Regina
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of TECHER David
> Sent: Monday, June 18, 2007 6:16 PM
> To: mgleahy at alumni.uwaterloo.ca; PostGIS Users Discussion
> Subject: Re: [postgis-users] Combined Windows version of PostGIS/P-LR
> Mike Leahy a écrit :
>> Hey all,
>> I'm just wondering if this thread should move back to the plr-general
>> list. In particular, I think it would be good if Joe is able to add a
>> link to the installer on the PL/R web page. I just tried the installer,
>> and it works great - nice work David.
>> I did notice, however, that it claims to be installing PgRouting in the
>> welcome screen, and it appears as PgRouting in the Windows uninstall
>> list.
> Well I did the installer, last Saturday night and I was hurry.
> You know when you haven't slept all a night, you don't see errors
> thanks.
>> Also, I think more than is needed is being added to the Path
>> variable. In my case, this is what gets added after the installer is done:
>> "\;C:\Program Files\R\R-2.5.0\bin;C:\Program
>> Files\PostgreSQL\8.2\bin;C:\Program Files\PostgreSQL\8.2\lib"
> I reduced it to
>> When I had installed PL/R manually, I seemed to be able to get away with
>> adding just ";C:\Program Files\R\R-2.5.0\bin".
> Yes it is, you're right. But if you use a function like
> select load_r_typenames();
> pl/r needs to know what it you R_HOME environment variable.
>> Also, if I happen to
>> re-install PL/R, the entire string above will appear multiple times in
>> the Path variable. Is it possible for the installer to check for that?
> I've only been able to detect if R directory is present in PATH variable
> for the moment!
> Not able to remove it for the moment from a previous install
> If you want, my Inno Setup script is available at
> http://www.davidgis.fr/download/plr-8.2.0.4-win32-src.zip
> If someone is used here to using Inno SetUp, no problem to improve it.
>> Regards,
>> Mike
>> TECHER David wrote:
>>> Hi Regina,
>>> Many thanks for these interesting link! Very excellent!
>>> I will wait for the next series of your articles!
>>> --david;
>>> Obe, Regina a écrit :
>>>> Since Dave was doing his part, I figured I would help out the cause a
>>>> little. R is pretty new to me too but looks like it could be very useful.
>>>> I drafted up a quick getting started and included David's link in there.
>>>> http://www.bostongis.com/PrinterFriendly.aspx?content_name=postgresql_plr_tut01
>>>> Let me know any parts that seem unclear or where I went wrong. The
>>>> steps seemed to work for me.
>>>> Thanks,
>>>> Regina
>>>> *From:* postgis-users-bounces at postgis.refractions.net on behalf of
>>>> TECHER David
>>>> *Sent:* Sun 6/17/2007 2:53 AM
>>>> *To:* PostGIS Users Discussion
>>>> *Subject:* Re: [postgis-users] Combined Windows version of PostGIS/P-LR
>>>> Dear Jan,
>>>> I begun to use PL/R. As you know, I'm not a expert in R
>>>> Compiling with PostgreSQL 8.2.4 on win32 ...no problem!
>>>> These release is available at
>>>> http://www.davidgis.fr/download/plr-8.2.0.4_0_win32.exe
>>>> I've tryed to see here if
>>>> first R 2.5.0 is available on the computer where you want to install it.
>>>> else it stop!
>>>> The installer updates the R_HOME environment variable
>>>> and update the PATH in order to adding 'R_HOME'/bin directory
>>>> Let me know if it works for you
>>>> createdb testR
>>>> psql -d testR -f / "path/to/your/postgresql/dir"/share/contrib/plr.sql
>>>> psql testR
>>>> select load_r_modules();
>>>> select * from plr_environ();
>>>> and so on
>>>> --david;
>>>> Jan Hartmann a écrit :
>>>>> I agree. A separate installer for PL/R would be the first thing to
>>>>> create. Am I right that that would not be very difficult? After that,
>>>>> though, I would very much like to have a *combined* version, with PL/R
>>>>> and PostGIS both enabled. I am not sure how difficult that would be,
>>>>> but, as I said, it would be a marvelous example of Open Source
>>>>> software cooperation. The additional packages Mike mentioned don't
>>>>> have to be installed prior to installing PL/R; you can install them in
>>>>> the regular way in R (R INSTALL), and an existing PostgreSQL database
>>>>> with PL/R will recognise them after a restart.
>>>>> BTW: deldir was a major reason for me to experimnt with a combined
>>>>> version: the power of voronoi diagrams in a PostGIS database!
>>>>> Jan
>>>>> Mike Leahy wrote:
>>>>>> David/Jan:
>>>>>> Although PostGIS and PL/R can be complimentary tools, I think a
>>>> separate
>>>>>> installer (for now at least) would make the most sense for PL/R. At
>>>>>> least that way there is still the option for other users to install
>>>> PL/R
>>>>>> without PostGIS, and vice-versa.
>>>>>> At the same time, however, I can see how a including PL/R as an option
>>>>>> in the PostGIS installer could be useful - particularly if a set of
>>>>>> pre-defined functions were included with the setup that made use of
>>>> PL/R
>>>>>> for spatial statistical operations within PostGIS. But this might
>>>> get a
>>>>>> bit complicated, considering the requirements involved (e.g., having R
>>>>>> installed, as well as packages installed in R - such as deldir for
>>>>>> making voronoi polygons).
>>>>>> Mike
>>>>>> TECHER David wrote:
>>>>>>> Hi Jan,
>>>>>>> Before I made a mistake, all you want is only a win32-installer for
>>>>>>> PL/R?
>>>>>>> because I think you know that's postgis win32-installer already
>>>> exist?
>>>>>>> See http://www.postgis.org/download/windows/
>>>>>>> --david;
>>>>>>>> Hi folks (sorry for crossposting),
>>>>>>>> Joe Conway just announced that PL/R will soon be available for
>>>>>>>> Windows. See the thread starting at:
>>>> http://gborg.postgresql.org/pipermail/plr-general/2007-June/000235.html
>>>>>>>> PL/R is an implementation of the statistical package R within
>>>>>>>> PostgreSQL. See:
>>>>>>>> http://www.joeconway.com/plr/
>>>>>>>> http://www.r-project.org <http://www.r-project.org/>
>>>>>>>> It's installed the same way as postGIS, but until now only a Linux
>>>>>>>> version was available. I have them both enabled on my server at SARA
>>>>>>>> computing center, and the functionality is unbelievable. My own
>>>>>>>> organisation, however, doesn't allow me to install Linux servers,
>>>> and
>>>>>>>> even if they did, neither staff nor students would be willing or
>>>> even
>>>>>>>> able to work with them. I guess this is not a unique situation, so
>>>>>>>> this Windows port is really important. Moreover, a PostgreSQl
>>>>>>>> implementation with full GIS and statistical functionality is
>>>>>>>> something that doesn't exist in the commercial world as far as I
>>>> know.
>>>>>>>> An easy installable Windows version would IMO really be a showpiece
>>>>>>>> for Open Source software. I would really appreciate if people in the
>>>>>>>> know on both these lists would put their heads together to implement
>>>>>>>> this. I don't really know much about Windows installers, but my
>>>>>>>> feeling is that it is not enormously difficult.
>>>>>>>> Regards,
>>>>>>>> Jan Hartmann
>>>>>>>> Dr. J. Hartmann
>>>>>>>> Department of Geography
>>>>>>>> University of Amsterdam
>>>>>>>> _______________________________________________
>>>>>>>> postgis-users mailing list
>>>>>>>> postgis-users at postgis.refractions.net
>>>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>> ___________________________________________________________________________
>>>>>>> Yahoo! Mail r?invente le mail ! D?couvrez le nouveau Yahoo! Mail
>>>> et son
>>>>>>> interface r?volutionnaire.
>>>>>>> http://fr.mail.yahoo.com <http://fr.mail.yahoo.com/>
>>>> Yahoo! Mail rinvente le mail ! Dcouvrez le nouveau Yahoo! Mail et son
>>>> interface rvolutionnaire.
>>>> *The substance of this message, including any attachments, may be
>>>> confidential, legally privileged and/or exempt from disclosure
>>>> pursuant to Massachusetts law. It is intended solely for the
>>>> addressee. If you received this in error, please contact the sender
>>>> and delete the material from any computer. *
>>> Yahoo! Mail r?invente le mail ! D?couvrez le nouveau Yahoo! Mail et son
> Yahoo! Mail réinvente le mail ! Découvrez le nouveau Yahoo! Mail et son interface révolutionnaire.
