[postgis-users] Midpoint function?
Pradeep B V pradeepbv at gmail.com
Thu Jun 21 07:28:28 PDT 2007
On 6/21/07, Nicolas Ribot <nicky666 at gmail.com> wrote:
> then you should reload your shapefile, using the -S switch to force
> creation of simple objects.
Will try this.
Or else try using st_line_merge().
This works fine. thanks a lot.
- Pradeep B V
Nicolas
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070621/ac8646da/attachment.html>
