[postgis-users] Midpoint function?
Pradeep B V
pradeepbv at gmail.com
Fri Jun 22 21:14:42 PDT 2007
Thanks Rodrigo.
- Pradeep B V
www.btis.in
On 6/22/07, Rodrigo Martín LÓPEZ GREGORIO <
rodrigomartin at lopezgregorio.com.ar> wrote:
> Ok, here is the function. It takes two parameters. The first is a
> LINESTRING or a MULTILINESTRING and the second is the location, similar as
> line_interpolate_point function. I think it works ok. Obviously if the
> MULTILINESTRING have gaps between constituent LINESTRINGs and the location
> is right in a "discontinuity" point it will return just one of the point (a
> kind of mathematical "left limit" I think although I didn't make several
> test about that).
> I hope it will be useful for someone. Here goes the code:
> -- Function: multiline_interpolate_point(amultils geometry,location
> float8)
> -- DROP FUNCTION multiline_interpolate_point(amultils geometry,location
> float8);
> CREATE OR REPLACE FUNCTION multiline_interpolate_point(amultils
> geometry,location float8)
> RETURNS geometry AS
> $BODY$
> DECLARE
> accumlength float8;
> totallength float8;
> nearestpoint geometry;
> i integer;
> BEGIN
> IF ((location < 0) or (location > 1)) THEN
> RAISE EXCEPTION 'location must be between 0 and 1 --> %', location;
> END IF;
> IF (GeometryType(amultils) != 'LINESTRING') and
> (GeometryType(amultils) != 'MULTILINESTRING') THEN
> RAISE EXCEPTION 'the geometry must be a LINESTRING or a
> MULTILINESTRING';
> END IF;
> IF (GeometryType(amultils) = 'LINESTRING') THEN
> nearestpoint:=line_interpolate_point(amultils,location);
> RETURN nearestpoint;
> END IF;
> accumlength := 0;
> totallength := Length(amultils);
> FOR i IN 1 .. NumGeometries(amultils) LOOP
> IF ((accumlength + Length(GeometryN(amultils,i))/totallength) >=
> location) THEN
> IF
> ((location-accumlength)/(Length(GeometryN(amultils,i))/totallength) > 1)
> THEN
> nearestpoint:=line_interpolate_point(GeometryN(amultils,i),1);
> ELSE
> nearestpoint:=line_interpolate_point(GeometryN(amultils,i),(location-accumlength)/(Length(GeometryN(amultils,i))/totallength));
> END IF;
> EXIT;
> ELSE
> accumlength:=accumlength+Length(GeometryN(amultils,i))/totallength;
> END IF;
> END LOOP;
> END;
> $BODY$
> LANGUAGE 'plpgsql' IMMUTABLE STRICT;
> ALTER FUNCTION multiline_interpolate_point(amultils geometry,location
> float8) OWNER TO postgres;
> Rodrigo.
> > I don't know why I mixed my ideas. The function that I send in my
> > previous mail find the nearest point of a multilinestring to a given point
> > so it has nothing to do with the middle point in the multilinestring.
> > Tomorrow I will modify that function and I'll send it again. Sorry about
> > that.
> > Rodrigo.
> > On 6/21/07, Rodrigo Martín LÓPEZ GREGORIO <rodrigomartin at lopezgregorio.com.ar> wrote:
> > > I was testing the LineMerge() solution with different MULTILINESTRINGs
> > > and it will only return a LINESTRING geometry if there is no gap between
> > > constituent linestrings. I remember then that a few days ago I answered a
> > > similar question but that time the linestrings had gaps and I tryed with
> > > LineMerge with no luck, so that time I created a function that work with
> > > those MULTILINESTRINGs. I know that the LineMerge solution works fine in
> > > your case but I send again the code of the function I created. I know maybe
> > > there could be a better solution but at least it works :P
> > > [...] So I wrote a stored function (preety simple by the way) that get
> > > what you need. The function get two parameters... the first is a
> > > multilinestring, the second, your point. The function loops over all
> > > linestrings in the multilinestring, get the nearest one and then with that
> > > linestring calculates the location of the nearest point of the linestring to
> > > your point. To get this function working run this script and it will create
> > > your function (take a look at the end of the function and chanche the user
> > > name if necesary; mine was postgres):
> > > -- Function: multiline_locate_point(amultils geometry,apoint geometry)
> > > -- DROP FUNCTION multiline_locate_point(amultils geometry,apoint
> > > geometry);
> > > CREATE OR REPLACE FUNCTION multiline_locate_point(amultils
> > > RETURNS geometry AS
> > > $BODY$
> > > DECLARE
> > > mindistance float8;
> > > nearestlinestring geometry;
> > > i integer;
> > > BEGIN
> > > mindistance := (distance(apoint,amultils)+100);
> > > if distance(apoint,GeometryN(amultils,i)) < mindistance THEN
> > > mindistance:=distance(apoint,GeometryN(amultils,i));
> > > nearestlinestring:=GeometryN(amultils,i);
> > > END IF;
> > > END LOOP;
> > > nearestpoint:=line_interpolate_point(nearestlinestring,line_locate_point(nearestlinestring,apoint));
> > > END;
> > > $BODY$
> > > ALTER FUNCTION multiline_locate_point(amultils geometry,apoint
> > > geometry) OWNER TO postgres;
> > > Once the function is stored and available for use, you can make the
> > > query like:
> > > SELECT *, multiline_locate_point(the_geom,PointFromText('POINT(517651
> > > 2121421)', 42102))
> > > FROM mainroad ORDER BY Distance(the_geom,PointFromText('POINT(517651
> > > 2121421)', 42102)) LIMIT 1
> > > However, the query speed is a little bit slow if you do the query in
> > > that way. You can use the next query instead wich first gets the nearest
> > > multilinestring to your point and then call my function with that geometry
> > > instead of calling the function for all geometries:
> > > _geom,PointFromText('POINT(517651 2121421)', 42102)) FROM
> > > (SELECT *, Distance(the_geom,PointFromText('POINT(517651 2121421)',
> > > 42102)) as dist
> > > 2121421)', 42102)) LIMIT 1 ) as foo
> > > On my PC the second query takes 1/6 of the time that tooks the first
> > > one so the speed is much better at least here ;)
> > > Rodrigo
> > > > > wrote:
> > > > > As Nicolas says you should use:
> > > > > select line_interpolate_point(LineMerge(the_geom),0.5).
> > > > > you can try this and see if the point is the one you want:
> > > > It works fine.
> > > > and here is the proof.
> > > > select distance(startpoint(the_geom),
> > > > line_interpolate_point(LineMerge(the_geom),0.5)) as stdist,
> > > > distance(endpoint(the_geom), line_interpolate_point(LineMerge(the_geom),
> > > > 0.5)) as endist from testdataset limit 1;
> > > > stdist | enddist
> > > > 0.000737003466840363 | 0.000737003466840363
> > > > Thanks Rodrigo/Nicolas.
> > > > - Pradeep B V
> > > > www.btis.in
> > > > _______________________________________________
> > > > postgis-users mailing list
> > > > postgis-users at postgis.refractions.net
> > > > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070623/2da90e21/attachment.html>
