[postgis-users] Re: [Plr-general] Tutorial on PLR and PostGIS, more on carriage returns
Paul Ramsey
pramsey at refractions.net
Thu Jun 21 09:50:02 PDT 2007
Danger, will Robinson. All values are fair game in bytes 2,3,4 of
the UTF encodings, so yes, it's possible you'll wreck multi-byte
characters by doing a simple replacement on the byte array. Better
to use an encoding-aware string replace function (not knowing C, I
don't know what that would be, but there must be some in the PgSQL
code base).
P
On 21-Jun-07, at 7:03 AM, Joe Conway wrote:
> Obe, Regina wrote:
>> Joe,
>> Can you take a look at it again. It was messed up in my firefox
>> too. I think originally I had it looking right in Firefox, but
>> then IE it didn't look right so I changed it to look right in IE,
>> but forgot to check back in firefox. Hopefully this time I have
>> made all browser masters happy.
> http://www.bostongis.com/PrinterFriendly.aspx?
> content_name=postgresql_plr_tut02
> The tutorial looks perfect now in Firefox on Fedora Core 7.
> BTW, I have confirmed on the R-devel list that the R engine is
> expecting \n for EOL, and \r will cause a syntax error, on all
> platforms. I will probably fix this by simply replacing \r with \n
> in PL/R functions. My only reservation is whether this might cause
> issues for installations with multibyte characters. Does anyone
> know if it is possible for multibyte characters to include a byte =
> 13 (\r), i.e. is the simple replacement of \r safe in all locales?
> Thanks,
> Joe
> postgis-users mailing list
