[postgis-users] ogr2ogr S57 question
Mark Cave-Ayland
mark.cave-ayland at ilande.co.uk
Sun Jun 24 10:07:30 PDT 2007
On Sun, 2007-06-24 at 12:34 -0400, Kurt Schwehr wrote:
> Hi All,
> I'm having trouble with a NOAA electronic chart that I am trying to
> put into postgres without success. I don't seem to be able to access
> the tables.
> http://vislab-ccom.unh.edu/~schwehr/ENC/NOAA/US5NH02M.000.bz2
> Here is what I am doing an the error that I am getting... using Mac
> OSX 10.4.10 with fink
> i postgis82 1.2.1-1024 PostgreSQL geographic object
> support
> i postgresql82 8.2.4-1021 PostgreSQL open-source database
> i postgresql82-dev 8.2.4-1021 PostgreSQL development
> headers and libraries
> i postgresql82-shlibs 8.2.4-1021 PostgreSQL shared libraries
> createdb s57
> sudo -u postgres /sw/bin/psql-8.2 -f /sw/share/doc/postgis82/
> lwpostgis.sql -d s57
> ogr2ogr -f PostgreSQL PGL:dbname=s57 US5NH02M.000
> psql -l
> List of databases
> Name | Owner | Encoding
> ais | postgres | SQL_ASCII
> postgres | postgres | SQL_ASCII
> s57 | schwehr | SQL_ASCII
> template0 | postgres | SQL_ASCII
> template1 | postgres | SQL_ASCII
> psql s57
> # Paste in the create command from pgadmin
> ERROR: relation "FAIRWY" already exists
> # Okay... so it looks like it is there until I try to select anything
> from it...
> s57=# SELECT * FROM FAIRWY;
> ERROR: relation "fairwy" does not exist
> What am I doing wrong?
> Thanks!
> -kurt
Hi Kurt,
PostgreSQL folds table names to lower case unless they are quoted in
double quotes - what does SELECT * FROM "FAIRWY" give you? Also
you can get a listing of tables in the database by using \d in psql.
HTH,
Mark.
ILande - Open Source Consultancy
http://www.ilande.co.uk
