[postgis-users] ogr2ogr S57 question
Kurt Schwehr
schwehr at ccom.unh.edu
Sun Jun 24 10:49:33 PDT 2007
Mark and Stephen,
Thanks much!!! That did it.
-kurt
On Jun 24, 2007, at 1:07 PM, Mark Cave-Ayland wrote:
> On Sun, 2007-06-24 at 12:34 -0400, Kurt Schwehr wrote:
>> Hi All,
>> I'm having trouble with a NOAA electronic chart that I am trying to
>> put into postgres without success. I don't seem to be able to access
>> the tables.
>> http://vislab-ccom.unh.edu/~schwehr/ENC/NOAA/US5NH02M.000.bz2
>> Here is what I am doing an the error that I am getting... using Mac
>> OSX 10.4.10 with fink
>> i postgis82 1.2.1-1024 PostgreSQL geographic object
>> support
>> i postgresql82 8.2.4-1021 PostgreSQL open-source
>> database
>> i postgresql82-dev 8.2.4-1021 PostgreSQL development
>> headers and libraries
>> i postgresql82-shlibs 8.2.4-1021 PostgreSQL shared libraries
>> createdb s57
>> sudo -u postgres /sw/bin/psql-8.2 -f /sw/share/doc/postgis82/
>> lwpostgis.sql -d s57
>> ogr2ogr -f PostgreSQL PGL:dbname=s57 US5NH02M.000
>> psql -l
>> List of databases
>> Name | Owner | Encoding
>> ais | postgres | SQL_ASCII
>> postgres | postgres | SQL_ASCII
>> s57 | schwehr | SQL_ASCII
>> template0 | postgres | SQL_ASCII
>> template1 | postgres | SQL_ASCII
>> psql s57
>> # Paste in the create command from pgadmin
>> ERROR: relation "FAIRWY" already exists
>> # Okay... so it looks like it is there until I try to select anything
>> from it...
>> s57=# SELECT * FROM FAIRWY;
>> ERROR: relation "fairwy" does not exist
>> What am I doing wrong?
>> Thanks!
>> -kurt
> Hi Kurt,
> PostgreSQL folds table names to lower case unless they are quoted in
> double quotes - what does SELECT * FROM "FAIRWY" give you? Also
> you can get a listing of tables in the database by using \d in psql.
> HTH,
> Mark.
> ILande - Open Source Consultancy
> http://www.ilande.co.uk
> postgis-users mailing list
