[postgis-users] PostGIS SRID pb when insert feature throughWFSv1.1 Geoserver
Sébastien Geindre sebastien.geindre at meteo.fr
Wed Jun 27 07:39:32 PDT 2007
Nicolas Ribot a écrit :
>> hi all,
>> Sorry for cross posting, i don't know if it is a geoserver (geotools)
>> problem or a postGIS configuration one.
>> I have this exception when trying to insert feature in PostGIS through
>> WFS V1.1 Geoserver 1.6
>> 27 juin 15:01:05 ERROR [data.jdbc] - SQL Exception writing geometry
>> columnERREUR: La nouvelle ligne pour la relation «ice_geom» viole la
>> contrainte de vérification «enforce_srid_ice_polygon»
>> org.postgresql.util.PSQLException: ERREUR: La nouvelle ligne pour la
>> relation «ice_geom» viole la contrainte de vérification
>>         at
> Hi Sebastien
> It seems there is a difference between the ice_polygon SRiD in postgis
> and the one sent by the WFS query.
> In geoserver, is ice_geom layer configured with the same SRID as
> ice_geom table in postgis ?
> WFS refers to EPSG:4326 for the ice_geom layer.
You are right.
srid of postGIS column and srid of gml data posted to wfs geoserver were
different (-1 and 4326).
i droped down the constraint on column, change the srdi and create
another constraint.
WFS works fine, loads feature into postGIS.
Merci nico !
> what's the output of the following query:
> select srid(the_geom) from ice_geom;
> Nicolas
> postgis-users mailing list
Sébastien Geindre
DPREVI/AERO/DEV
sebastien.geindre __at__ meteo.fr
05 61 07 84 93
