[postgis-users] Boundary() without the internal holes?
John Carnes john at maptools.com
Thu Mar 1 09:25:11 PST 2007
Thanks Brad,
ExteriorRing() did the job.
For the benefit of list searchers in the future...
The problem at hand was to create a boundary around a bunch of land
parcels that make up a neighborhood.
The space taken up by the streets is "empty" in that there is no
polygon to represent it.
Step 1 was to add a neighborhood attribute and get it set to the
correct value.
Step 2 was to add some small polygons to block off the street
openings at the boundaries of the neighborhood. I gave them all a
special tag that makes it easy to remove them when I'm finished.
Step 3 was to create the boundary using the ExteriorRing() function.
The query for an individual neighborhood looks like this:
INSERT INTO n_bounds (neighborhood,the_geom) SELECT
p.neighborhood,MakePolygon(ExteriorRing(geometryN(geomunion
(p.the_geom),1)))
FROM parcels AS p WHERE p.neighborhood=6;
Form a computational standpoint, I suspect this query is a disaster,
but this is a one time shape generation, so waiting a bit longer for
the result makes no difference.
John Carnes
MapTools
On Feb 28, 2007, at 3:57 PM, Brad Ediger wrote:
> Sounds like you're looking for ExteriorRing(polygon). A polygon has
> one exterior ring and zero or more interior rings. ExteriorRing is
> a lot cheaper (computationally) than calculating a convex hull or
> boundary.
> Documentation here -> http://postgis.refractions.net/docs/ch06.html
> Brad
> On Feb 28, 2007, at 5:30 PM, John Carnes wrote:
>> I am trying to figure out how to get a polygon that is the
>> boundary of a geounion of polygons without getting polygons for
>> the internal holes.
>> The boundary() function is close, but includes the internal holes.
>>     SELECT boundary(geomunion(p.the_geom)) FROM parcels AS p WHERE
>> p.neighborhood=5;
>> A convex hull, leaves out the internal holes, but the resulting
>> polygon doesn't touch the actual boundary anywhere that it is
>> concave.
>> Thanks in advance for your ideas on how to do this.
>> I'd really like to avoid having to delete the internal hole
>> polygons by hand, which is my current solution.
>> John Carnes
>> MapTools
