[postgis-users] Re: zcta census data, help with query
Matt Bartolome
mattxbart at gmail.com
Thu Mar 1 10:39:53 PST 2007
Ok, so I went back and looked over what I had done to import the data
and one stupid error I think I made was here:
shp2pgsql -s 2230 -d zt06_d00.shp public.ziptest > zip.sql
Census docs say that the SRID for the zcta data is actually 4269
(lon,lat). So I re-imported the generated sql with the correct srid
param and tested the data with the query:
select zcta, x(centroid(transform(the_geom, 4269))) as longitude,
y(centroid(transform(the_geom, 4269))) as latitude from ziptest where
zcta = 92116;
zcta | longitude | latitude
92116 | -117.121819788206 | 32.7655437135842
The point appears where I think it should however I still get false
when doing my within or contains queries:
SELECT zcta, contains (Transform(SetSRID(MakePoint(-117.119403,
32.771608),4269),4269), the_geom) from ziptest where zcta = 92116;
zcta | contains
92116 | f
(1 row)
Thanks to anyone who can help me out,
Matt
On 2/28/07, Matt Bartolome <mattxbart at gmail.com> wrote:
> Hello List,
> I have loaded zt06_d00.shp (california zcta) data from
> http://www.census.gov/geo/www/cob/z52000.html
> Using the shp2pgsql utility:
> I am able to load the data into my postgres database with no problem.
> Dumping shapefiles and some other things I've tried work great.
> My problem right now is doing the query:
> SELECT zcta, WITHIN (Transform(SetSRID(MakePoint(-117.119403,
> 32.771608),4269),2230), the_geom) as within from ziptest;
> This should fall within zipcode 92116 but it is showing false. Can
> anybody "point" me in the right direction?
> Thanks,
> Matt
