[postgis-users] How to add circle to Postgis database?
Brad Ediger brad at bradediger.com
Wed Mar 7 11:51:37 PST 2007
On Mar 7, 2007, at 1:36 PM, Jeremy Dunck wrote:
> On 3/7/07, Brad Ediger <brad at bradediger.com> wrote:
>> On Mar 7, 2007, at 12:59 PM, Brent Wood wrote:
>> > There is unfortunately a nasty trap here, as the point will need
>> to be
>> > reprojected to a suitable equidistant or equal area projection to
>> > generate a
>> > true circle, ...
>> (SRID 27582 is a Lambert II planar projection, as measured in
>> meters.)
>> CREATE OR REPLACE FUNCTION circle(geometry, numeric) RETURNS geometry
>>      AS 'SELECT Transform(SetSRID(Buffer(Transform(SetSRID($1, 4326),
>> 27582), $2), 27582), 4326);'
>>    LANGUAGE sql;
> Hmm, if I understand correctly, Lambert is conformal, which doesn't
> fit the  criteria suggested by Brent (i.e. equidistant or equal-area).
> I'm a newbie at this stuff, so it's fairly likely I'm missing
> something.  :-/
> I'm jumping in here because I have the same desire to use a circle
> around a given point.  Cheers for the pointers so far!
OK, you got me. On two counts:
1) I didn't fully read the original post, and
2) I'm a programmer, not a cartographer.
Well, you learn something new every day. I think Lambert II is
conformal, so that wouldn't help the OP. But aren't there equal-area
(azimuthal and cylindrical) Lambert projections as well? I defer to
someone who has real experience in geodesy, rather than my pretend
experience. :-)
be
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070307/cccc276e/attachment.bin>
