[postgis-users] How to add circle to Postgis database?
Brad Ediger
brad at bradediger.com
Wed Mar 7 11:54:53 PST 2007
On Mar 7, 2007, at 1:36 PM, Jeremy Dunck wrote:
> On 3/7/07, Brad Ediger <brad at bradediger.com> wrote:
>> On Mar 7, 2007, at 12:59 PM, Brent Wood wrote:
>> > There is unfortunately a nasty trap here, as the point will need
>> to be
>> > reprojected to a suitable equidistant or equal area projection to
>> > generate a
>> > true circle, ...
>> (SRID 27582 is a Lambert II planar projection, as measured in
>> meters.)
>> CREATE OR REPLACE FUNCTION circle(geometry, numeric) RETURNS geometry
>> AS 'SELECT Transform(SetSRID(Buffer(Transform(SetSRID($1, 4326),
>> 27582), $2), 27582), 4326);'
>> LANGUAGE sql;
> Hmm, if I understand correctly, Lambert is conformal, which doesn't
> fit the criteria suggested by Brent (i.e. equidistant or equal-area).
> I'm a newbie at this stuff, so it's fairly likely I'm missing
> something. :-/
> I'm jumping in here because I have the same desire to use a circle
> around a given point. Cheers for the pointers so far!
To amend my own post, here's what appears to be a Lambert equal-area
projection, supported by PROJ.4 (EPSG code 9820). Use at your own risk!
http://remotesensing.org/geotiff/proj_list/
lambert_azimuthal_equal_area.html
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070307/bbfa1bf5/attachment.bin>
