[postgis-users] optimize query
Rob Tester
robtester at gmail.com
Fri Mar 9 08:10:28 PST 2007
Add a where clause on the indexed column (presumably f.geometry).
WHERE f.geometry&& geomfromtext('POINT(-9.1533 38.69686)',4326)
Rob.
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Pedro
Doria Meunier
Sent: Friday, March 09, 2007 9:04 AM
To: 'PostGIS Users Discussion'
Subject: [postgis-users] optimize query
Importance: High
Hi List,
I'm once again in need of guru advice. J
This is the query:
select freguesia, distance(geomfromtext('POINT(-9.1533
38.69686)',4326),f.geometry) as thedist
from freguesias as f
order by thedist
limit 1;
as you can see it returns the closest polygon to a given point.
Problem: 4050 (**detailed**) polygons
exec time: 907 ms
The Gist index was created, btw.
Is there any way to optimize this query and avoid the dreaded seq scan?
Txs in advance!
Pedro Doria Meunier.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070309/3096ac6b/attachment.html>
