[postgis-users] optimize query
Obe, Regina robe.dnd at cityofboston.gov
Fri Mar 9 09:57:56 PST 2007
I think using expand instead of buffer would be much more efficient since expand is a much simpler process than buffer and the && would then reduce back to a bounding box compare anyway, but in this case it probably doesn't matter too much since it is a static point you are buffering.
From: postgis-users-bounces at postgis.refractions.net on behalf of Pedro Doria Meunier
Sent: Fri 3/9/2007 12:18 PM
To: 'PostGIS Users Discussion'
Subject: RE: [postgis-users] optimize query
Paul and Rob,
First of all thanks for your time!
This is the way I solved it in terms of speed...
select freguesia, distance(geomfromtext('POINT(-9.17266 38.68783)',4326),f.geometry) as thedist
from warped_freguesias as f
WHERE f.geometry && buffer(geomfromtext('POINT(-9.17266 38.68783)',4326), 0.016)
order by thedist
limit 1;
I used roughly a nautical mile...
Now my query returns in 15ms :P
Pedro Doria Meunier
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Rob Tester
Sent: sexta-feira, 9 de Março de 2007 16:56
Yeah, it helps when you fully read the question before answering,  sorry about that.
What I do in cases like you present is to create a buffer around the point to create an area where that would find another object or return an error. For instance I need to find the 'nearest' road to a point, if that point falls within a city geometry, I create a buffer that is roughly 1 statute mile, if it is rural then I use a 5 mile buffer. In these cases if I don't find a road close by, then it would be an error. Don't know if that would help you in your case or not.
You could write a simple stored procedure that expanded the buffer to a max limit if the query wasn't returning any geometries. Of course that would only help if your table is big and speed of executing multiple queries against the index was faster than doing a seq scan.
Rob
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Pedro Doria Meunier
Sent: Friday, March 09, 2007 9:35 AM
Importance: High
Boy that was *fast*! J
Txs guys!
Anyway... you're right Rob; but only if the point is inside the polygons... if not the query returns zilch...
Think of the case when a vehicle is crossing a bridge... ;-)
Pedro.
Sent: sexta-feira, 9 de Março de 2007 16:10
Add a where clause on the indexed column (presumably f.geometry).
WHERE f.geometry&& geomfromtext('POINT(-9.1533 38.69686)',4326)
Rob.
Sent: Friday, March 09, 2007 9:04 AM
Subject: [postgis-users] optimize query
Importance: High
Hi List,
I'm once again in need of guru advice... J
This is the query:
select freguesia, distance(geomfromtext('POINT(-9.1533 38.69686)',4326),f.geometry) as thedist
from freguesias as f
order by thedist
limit 1;
as you can see it returns the closest polygon to a given point.
Problem: 4050 (**detailed**) polygons
exec time: 907 ms
The Gist index was created, btw...
Is there any way to optimize this query and avoid the dreaded seq scan?
Txs in advance!
Pedro Doria Meunier.
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070309/275048cb/attachment.html>
