[postgis-users] optimize query
Pedro Doria Meunier
pdoria at netmadeira.com
Fri Mar 9 10:15:36 PST 2007
Regina,
As always your input is highly appreciated. Thank you!
Pedro.
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Obe,
Regina
Sent: sexta-feira, 9 de Março de 2007 17:58
To: PostGIS Users Discussion
Subject: RE: [postgis-users] optimize query
I think using expand instead of buffer would be much more efficient since
expand is a much simpler process than buffer and the && would then reduce
back to a bounding box compare anyway, but in this case it probably doesn't
matter too much since it is a static point you are buffering.
_____
From: postgis-users-bounces at postgis.refractions.net on behalf of Pedro Doria
Meunier
Sent: Fri 3/9/2007 12:18 PM
To: 'PostGIS Users Discussion'
Paul and Rob,
First of all thanks for your time!
This is the way I solved it in terms of speed
select freguesia, distance(geomfromtext('POINT(-9.17266
38.68783)',4326),f.geometry) as thedist
from warped_freguesias as f
WHERE f.geometry && buffer(geomfromtext('POINT(-9.17266 38.68783)',4326),
0.016)
order by thedist
limit 1;
I used roughly a nautical mile
Now my query returns in 15ms :P
Pedro Doria Meunier
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Rob
Tester
Sent: sexta-feira, 9 de Março de 2007 16:56
Yeah, it helps when you fully read the question before answering, sorry
about that.
What I do in cases like you present is to create a buffer around the point
to create an area where that would find another object or return an error.
For instance I need to find the nearest road to a point, if that point
falls within a city geometry, I create a buffer that is roughly 1 statute
mile, if it is rural then I use a 5 mile buffer. In these cases if I dont
find a road close by, then it would be an error. Dont know if that would
help you in your case or not.
You could write a simple stored procedure that expanded the buffer to a max
limit if the query wasnt returning any geometries. Of course that would
only help if your table is big and speed of executing multiple queries
against the index was faster than doing a seq scan.
Rob
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Pedro
Doria Meunier
Sent: Friday, March 09, 2007 9:35 AM
Importance: High
Boy that was *fast*! J
Txs guys!
Anyway... youre right Rob; but only if the point is inside the polygons
if
not the query returns zilch
Think of the case when a vehicle is crossing a bridge
Pedro.
Tester
Sent: sexta-feira, 9 de Março de 2007 16:10
Add a where clause on the indexed column (presumably f.geometry).
WHERE f.geometry&& geomfromtext('POINT(-9.1533 38.69686)',4326)
Rob.
Doria Meunier
Sent: Friday, March 09, 2007 9:04 AM
Subject: [postgis-users] optimize query
Importance: High
Hi List,
Im once again in need of guru advice
J
This is the query:
select freguesia, distance(geomfromtext('POINT(-9.1533
38.69686)',4326),f.geometry) as thedist
from freguesias as f
order by thedist
limit 1;
as you can see it returns the closest polygon to a given point.
Problem: 4050 (**detailed**) polygons
exec time: 907 ms
The Gist index was created, btw
Is there any way to optimize this query and avoid the dreaded seq scan?
Txs in advance!
Pedro Doria Meunier.
_____
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended solely for the
addressee. If you received this in error, please contact the sender
and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070309/ff83fb4a/attachment.html>
