[postgis-users] can not perform installation of pgRouting module for kamap
shilpi pasricha
ekpari84 at gmail.com
Sat Mar 17 07:38:27 PDT 2007
i tried to follow the steps as given in ominiverdi's wiki
i installed gual,boost,cgal with no errors
as given on this site: http://www.postlbs.org/postlbs-cms/en/node/21
but when i perform this step: PGSQL_PATH/bin/psql -f routing.sql routing
as given in step 3 of the above-mentioned link, i get the following errors:
http://rafb.net/p/tzO19J54.html
or:
# psql -f /usr/share/postgresql/8.2/contrib/routing.sql routing
psql:/usr/share/postgresql/8.2/contrib/routing.sql:22: ERROR: relation
"path_result" already exists
psql:/usr/share/postgresql/8.2/contrib/routing.sql:23: ERROR: relation
"vertex_result" already exists
psql:/usr/share/postgresql/8.2/contrib/routing.sql:33: ERROR: could not
load library "/usr/lib/postgresql/8.2/lib/routing.so": libgaul_util.so.0:
cannot open shared object file: No such file or directory
psql:/usr/share/postgresql/8.2/contrib/routing.sql:44: ERROR: could not
psql:/usr/share/postgresql/8.2/contrib/routing.sql:53: ERROR: could not
psql:/usr/share/postgresql/8.2/contrib/routing.sql:63: ERROR: could not
psql:/usr/share/postgresql/8.2/contrib/routing.sql:74: ERROR: could not
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
i tried re compiling BOOST,GAUL,CGAL.
but the same errors sprout back..
what could be wrong ?
plz help!
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070317/be0fbd62/attachment.html>
