[postgis-users] a newbie question
Obe, Regina
robe.dnd at cityofboston.gov
Wed Mar 21 05:55:19 PDT 2007
You can also just explicitly add the records into geometry_columns table with a statement like
INSERT INTO geometry_columns(f_table_column, f_table_schema, f_table_name, f_geometry_column, coord_dimension, srid, type)
SELECT f_table_column, f_table_schema, 'mynewtable', f_geometry_column, coord_dimension, srid, type
FROM geometry_columns where f_table_name = 'myoldtable'
As David mentioned for a lot of clients you need a primary key in addition to entry in geometry_columns and copying a table doesn't copy the constraints and keys so you would need to explicitly recreate those you need or do a create with oid to have a dummy one.
Something like
ALTER TABLE mynewtable
ADD CONSTRAINT pk_mynewtable_gid PRIMARY KEY(gid);
also recreate gist indexes
CREATE INDEX idx_mynewtable_the_geom
ON mynewtable
USING gist
(the_geom);
Where mynewtable and myoldtable are just placeholders for your new and old table names.
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of TECHER David
Sent: Wednesday, March 21, 2007 8:30 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] a newbie question
Gustavo Ces a écrit :
> Sorry about this question,
> i want to create another table from selecting a previous one (
> with the_geom and gid)
> create table foo as select gid, the_geom, other_columns from
> previous_table
> this query creates the table with the other columns, gid and geom but
> if try to open it in a client, it fails.
> Which is the problem?
> Thanks,
> Galois
Hi Gustavo,
If your client fail so I suppose ythat your client is perhaps QGIS or
MapServer, it is because you don't specify a key or a oid
So do something like this with foo <=> communes_bourgogne and
other_columns <=> nom_comm, insee_comm
First create your table and populate it with oids and WITHOUT specify
the_geom
bourgogne=# create table test WITH OIDS as (select gid, nom_comm,
insee_comm from communes_bourgogne) ;
SELECT
then use the addgeometrycolumn() function properly:
bourgogne=# select addgeometrycolumn('test','the_geom',(select
srid(the_geom) from communes_bourgogne limit 1),(select
geometrytype(the_geom) from communes_bourgogne limit 1),2);
addgeometrycolumn
public.test.the_geom SRID:27582 TYPE:MULTIPOLYGON DIMS:2
(1 ligne)
times to populate the_geom
bourgogne=# UPDATE test set the_geom=communes_bourgogne.the_geom from
communes_bourgogne where communes_bourgogne.gid=test.gid; UPDATE 2042
bourgogne=#
if it doesn't work ...Il should be better to try pgsql2shp/shp2pgsql
(that's the old solution)
1) export as shp
pgsql2shp -f <shapefile.shp> -h localhost -u <user> <database> "select
the_geom, other_columns from previous_table"
YOU DON'T HAVE TO SPECIFY GID, IT SHOULD BE AUTOMATICALLY CREATE WHEN
YOU IMPORT IT
2) import into a new table
shp2pgsql -DI <table> <shapefile.shp> | psql <database>
then delete <shapefile.shp> <shapefile.shx> <shapefile.dbf>
> postgis-users mailing list
___________________________________________________________________________
Yahoo! Mail réinvente le mail ! Découvrez le nouveau Yahoo! Mail et son interface révolutionnaire.
http://fr.mail.yahoo.com
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
