[postgis-users] a newbie question
TECHER David davidtecher at yahoo.fr
Wed Mar 21 05:29:50 PDT 2007
Gustavo Ces a écrit :
> Sorry about this question,
>     i want to create another table from selecting a previous one (
> with the_geom and gid)
> create table foo as select gid, the_geom, other_columns from
> previous_table
> this query creates the table with the other columns, gid and geom but
> if try to open it in a client, it fails.
> Which is the problem?
> Thanks,
> Galois
Hi Gustavo,
If your client fail so I suppose ythat your client is perhaps QGIS or
MapServer, it is because you don't specify a key or a oid
So do something like this with  foo <=> communes_bourgogne and
other_columns <=> nom_comm, insee_comm
First create your table and populate it with oids and WITHOUT specify
the_geom
bourgogne=# create table test WITH OIDS as (select gid, nom_comm,
insee_comm from communes_bourgogne) ;
SELECT
then use the addgeometrycolumn() function properly:
bourgogne=# select addgeometrycolumn('test','the_geom',(select
srid(the_geom) from communes_bourgogne limit 1),(select
geometrytype(the_geom) from communes_bourgogne limit 1),2);
                    addgeometrycolumn
 public.test.the_geom SRID:27582 TYPE:MULTIPOLYGON DIMS:2
(1 ligne)
times to populate the_geom
bourgogne=# UPDATE test set the_geom=communes_bourgogne.the_geom from
communes_bourgogne where communes_bourgogne.gid=test.gid; UPDATE 2042
bourgogne=#
if it doesn't work ...Il should be better to try pgsql2shp/shp2pgsql
(that's the old solution)
1) export as shp
pgsql2shp -f <shapefile.shp> -h localhost -u <user> <database> "select
the_geom, other_columns from previous_table"
YOU DON'T HAVE TO SPECIFY GID, IT SHOULD BE AUTOMATICALLY CREATE WHEN
YOU IMPORT IT
2) import into a new table
shp2pgsql -DI <table> <shapefile.shp> | psql <database>
then delete <shapefile.shp> <shapefile.shx> <shapefile.dbf>
> postgis-users mailing list
___________________________________________________________________________
Yahoo! Mail réinvente le mail ! Découvrez le nouveau Yahoo! Mail et son interface révolutionnaire.
http://fr.mail.yahoo.com
