[postgis-users] can not perform installation of pgRouting module for kamap
pranjal
pranjal_24 at yahoo.com
Thu Mar 22 01:39:00 PDT 2007
thanks:)its working
regards
pranjal
Sean Fulton wrote:
> On 2007-03-17 11:08:27 -0400, "shilpi pasricha" <ekpari84 at gmail.com> said:
>> i tried to follow the steps as given in ominiverdi's wiki
>> i installed gual,boost,cgal with no errors
>> as given on this site: http://www.postlbs.org/postlbs-cms/en/node/21
>> but when i perform this step: PGSQL_PATH/bin/psql -f routing.sql routing
>> as given in step 3 of the above-mentioned link, i get the following
>> errors:
>> http://rafb.net/p/tzO19J54.html
>> i tried re compiling BOOST,GAUL,CGAL.
>> but the same errors sprout back..
>> what could be wrong ?
>> plz help!
> I had the same the problem. pgRouting has a problem in how it links
> libraries. I've haven't tried to find a proper fix but I did
> successfully work around it. The pgRouting library expects CGAL and
> GAUL libraries to be in the directory directly above it.
> For example:
> - If routing.so -> /usr/lib/pgsql/routing.so
> - it expects -> /usr/lib/libCGAL.so
> So, create sym links in the directory above routing.so to the actual
> libraries. You'll have to do this for libgaul and libgaul_util as well.
> Other options are to move the libraries or fix the pgRouting build
> process. I opted for the quick fix.
> Sean
> postgis-users mailing list
View this message in context: http://www.nabble.com/can-not-perform-installation-of-pgRouting-module-for-kamap-tf3419331.html#a9610387
Sent from the PostGIS - User mailing list archive at Nabble.com.
