[postgis-users] Re: Dilemma: is gid really useful in a geoDB?
Brad Ediger brad at bradediger.com
Fri Mar 23 11:15:23 PDT 2007
On Mar 23, 2007, at 1:03 PM, Sean Fulton wrote:
> On 2007-02-22 13:05:29 -0500, Brent Wood <pcreso at pcreso.com> said:
>> Making these fields optional does NOT make primary keys optional.
>> (well,
>> they are, but the relational model is well & truly broken if you
>> don't have one,
>> whether or not you actually define it as such. The data can have a
>> viable
>> primary key, even if it is not specified as such in the schema)
> Strictly speaking, the relational model is broken when there are
> non-unique tuples. When all tuples are unique, you have a de facto
> primary key -- the whole tuple. Uniqueness is, I think, the only
> requirement. A primary key is a convenience that summarizes the
> uniqueness of a tuple. In the fourth normal form and higher they
> are unnecessary.
If you want to get pedantic, the whole tuple would be a candidate
key. A candidate key is only a primary key when it is singled out as
such.
Back to our regularly scheduled programming...
be
