[postgis-users] Linestring 3DM?
paallen at attglobal.net
Fri Mar 23 13:31:12 PDT 2007
Hi all,
I am very new with PostGIS and I am trying to
build a database to manage bore-holes for mineral
exploration.
I want to store the curved 3d curved bore-hole
trace with the m (survey distances on the nodes)
values. Is this possible.
My following experiment has fail.
CREATE TABLE public.line3d_test
id integer,
name varchar,
CONSTRAINT line3d_test_id_pkey PRIMARY KEY (id);
SELECT AddGeometryColumn(public, line3d_test,
gline3dm, 32618, LINESTRING, 2);
INSERT INTO public.line3d_test (id, name,
gline3dm) VALUES ( 1, 'first-line',
GeomFromEWKT('LINESTRING(200000 900000 2000 0,
200001 900001 1900 100)', 32618));
If I use "GeomFromText" I get this error:
WARNING: OGC WKT expected, EWKT provided - use
GeomFromEWKT() for this
CONTEXT: SQL function "geomfromtext" statement 1
ERROR: new row for relation "line3d_test" violates
check constraint "enforce_dims_gline3dm"
SQL state: 23514
Then if I use "GeomFromEWKT()" I get this error:
ERROR: function geomfromewkt("unknown", integer)
does not exist
SQL state: 42883
Hint: No function matches the given name and
argument types. You may need to add explicit type
casts.
Character: 81
What I have I done wrong? Or is this even
possible? I know EWKT or EWKB is an extension of
OGC but I am working in 3D so I sort of need it.
thanks,
Phillip J. Allen
Consulting Geochemist
