[postgis-users] Linestring 3DM?
Julio Galindo
juliogalindoq at gmail.com
Fri Mar 23 14:10:34 PDT 2007
Hi Phillip,
Note that you have defined a 2D LINESTRING on AddGeometryColumn statement
and you must use 4D because you are inserting 4D data
Regards,
Julio
On 3/23/07, paallen at attglobal.net <paallen at attglobal.net> wrote:
> Hi all,
> I am very new with PostGIS and I am trying to
> build a database to manage bore-holes for mineral
> exploration.
> I want to store the curved 3d curved bore-hole
> trace with the m (survey distances on the nodes)
> values. Is this possible.
> My following experiment has fail.
> CREATE TABLE public.line3d_test
> id integer,
> name varchar,
> CONSTRAINT line3d_test_id_pkey PRIMARY KEY (id);
> SELECT AddGeometryColumn('public', 'line3d_test',
> 'gline3dm', 32618, 'LINESTRING', 2);
> INSERT INTO public.line3d_test (id, name,
> gline3dm) VALUES ( 1, 'first-line',
> GeomFromEWKT('LINESTRING(200000 900000 2000 0,
> 200001 900001 1900 100)', 32618));
> If I use "GeomFromText" I get this error:
> WARNING: OGC WKT expected, EWKT provided - use
> GeomFromEWKT() for this
> CONTEXT: SQL function "geomfromtext" statement 1
> ERROR: new row for relation "line3d_test" violates
> check constraint "enforce_dims_gline3dm"
> SQL state: 23514
> Then if I use "GeomFromEWKT()" I get this error:
> ERROR: function geomfromewkt("unknown", integer)
> does not exist
> SQL state: 42883
> Hint: No function matches the given name and
> argument types. You may need to add explicit type
> casts.
> Character: 81
> What I have I done wrong? Or is this even
> possible? I know EWKT or EWKB is an extension of
> OGC but I am working in 3D so I sort of need it.
> thanks,
> Phillip J. Allen
> Consulting Geochemist
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070323/72d3ed4f/attachment.html>
