[postgis-users] Hard upgrade questions in WIN
Robert Coup
robert.coup at onetrackmind.co.nz
Tue Mar 27 15:36:06 PDT 2007
Jonathan Aguero wrote:
> I work in the localhost and I don’t need the pg server on-line all the
> time so I think the easiest way to upgrade is to dump the database,
> uninstall postgis and pg, install pg 8.2 and the technology preview of
> postgis 1.2.1 and then run the postgis_restore.pl. Am I right with my
> approach?
> Now, this bring my other question: can I run the postgis_restore.pl
> script in windows? It seems like it is a LINUX script (sh) so I don’t
> know. If not, what should I do?
Tip: do a dump of the old db in plain text - just in case it all doesn't
work out. In a worst-case you can strip all the Postgis
function/operator/etc definitions out in an editor then restore it into
a DB you've set up with the new postgis.
Rob :)
One Track Mind Ltd.
PO Box 1604, Shortland St, Auckland, New Zealand
Phone +64-9-966 0433 Mobile +64-21-572 632
Web http://www.onetrackmind.co.nz
