[postgis-users] Re: [postgis-devel] Several R-Trees
Leticia
lgomez at itba.edu.ar
Thu Mar 29 06:22:28 PDT 2007
Sorry, I made a typo error. I am using the "&&" operator and I have run the
VACUUM ANALYZE over the two tables, prior to query the plan.
Could you help me?
Thanks a lot,
Leticia
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Mark
Cave-Ayland
Sent: Thursday, March 29, 2007 10:17 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Re: [postgis-devel] Several R-Trees
On Thu, 2007-03-29 at 09:51 -0300, Leticia wrote:
> Hello!
> I have two tables, each one with a geometry column.
> I have built two R-Tree indexes. i.e.
> Create index idxrivers2000 on rivers2000 using gist (geometry
> gist_geometry_ops)
> Create index idxcities2000 on cities2000 using gist (geometry
> gist_geometry_ops)
> Now, I need to make spatial join queries like this "how many cities
> are crossed by rivers?"
> SELECT COUNT(*)
> FROM rivers2000, cities2000
> WHERE rivers2000.geometry & cities2000.geometries AND
> interescts(rivers2000.geometry,cities2000.geometries )
> 1) The use of the "&" operator is to force the R-tree using in the
> query plan. If I do not use it, the index will not be chosen. Am I ok?
> 2) If I only use the subexpression "WHERE rivers2000.geometry &
> cities2000.geometries" it only use MBRs and It is not correct, as I
> need not only to use FIRST FILTER, but obtain and exact result.
> 3) When I look the query plan, I see that it uses only one of the
> indexes (INDEXSCAN on one of them), and then use a lookup table over
> the other table (SCAN TABLE over the other table). Is it possible to
> force Postgress/Postgis to use a Spatial Join (use the two indexes
> instead of using a table scan) ? How?
> Thanks in advance,
> Leticia
Hi Leticia,
I think you may be using the wrong operator - PostGIS requires the "&&"
operator to make use of the spatial indices, e.g.
SELECT COUNT(*)
WHERE rivers2000.geometry && cities2000.geometries AND
interescts(rivers2000.geometry,cities2000.geometries)
(I have no idea what effect the "&" operator would have on geometry
types)
Also, assuming you are using PostgreSQL >= 8.0, you need to issue a
VACUUM ANALYZE after creating the indices so that PostGIS can build up
the statistics it needs to correctly use them.
BTW, you don't need to post to postgis-devel since the postgis-devel
list is for PostGIS developer discussion - postgis-users is the correct
list for PostGIS application development questions.
HTH,
Mark.
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
