[postgis-users] Indexes not being used
Pedro Doria Meunier pdoria at netmadeira.com
Sat Mar 31 11:57:54 PDT 2007
Hi all (with a special wink to Regina ;- )
This is the query not using indices:
SELECT parish,county,geometry FROM pt_madeira_toponymy as t WHERE
parish=upper('se') AND
  t.geometry && geomfromtext('POINT(-16.9213592631455
32.6437878212273)',4326) AND
intersects(geomfromtext('POINT(-16.9213592631455 32.6437878212273)',4326),
t.geometry);
As you can plainly see it checks if a point is inside some polygon.
EXPLAIN ANALYZE returns this:
"Seq Scan on pt_madeira_toponymy t  (cost=0.00..3.03 rows=1 width=96)
(actual time=1.086..1.278 rows=1 loops=1)"
"  Filter: ((parish = 'SE'::text) AND (geometry &&
'0101000020E61000009B135F33DEEB30C0FFDDAAA367524040'::geometry) AND
intersects('0101000020E61000009B135F33DEEB30C0FFDDAAA367524040'::geometry,
geometry))"
"Total runtime: 1.312 ms"
The toponymy has two indices: one for 4326 and another for 32628 using GiST.
Is the intersects function not using indices at all??
Already thankful for any ideas,
With best regards,
Pedro Doria Meunier.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070331/65e0da4c/attachment.html>
