[postgis-users] Re: function to convert meters into degrees without reprojections
Galen
galen at shackprices.com
Sat Mar 31 14:15:53 PDT 2007
Brent, can you offer a projection newbie any advice on how to create a
'custom equal-area projection for my part of the world?'
Thanks,
Galen
I've generated millions of buffers on lines & points stored in EPSG:4326 by
(from memory) something like:
update <table> set buffer_geom=
transform(buffer(transform(geom,27201),<dist>,<n>),4326)
where 27201 is a custom equal-area projection for my part of the world & you
can set the required dist & n values for buffer to meet your requirements.
