[postgis-users] docs
Michael Welter mike at telecommatters.net
Tue May 1 04:36:01 PDT 2007
Thank you Brent,
I've been trying to access the specifications at opengeospatial.org
without success.  On my Mac OS X system I tried the Firefox browser,
Mozilla, Safari, and IE.
However, when I used my wife's Windows laptop using Firefox, I was able
to access the site.  Is someone from OGC listening?
Thanks,
Brent Wood wrote:
> --- Michael Welter <mike at telecommatters.net> wrote:
>> Where can I find docs for the PostGIS software?
>> For example, Contains(Polygon,Point) always returns false, but
>> Contains(Polygon,Polygon) returns the appropriate boolean.
> Do you have examples? That is not what I get:
> baw=# select contains(geomfromtext('POLYGON((0 0,0 2,2 2,2 0,0
> 0))',4326),geomfromtext('POINT(1 1)',4326));
>  contains
>  t
> (1 row)
> 0))',4326),geomfromtext('POINT(-1 1)',4326));
>  contains
>  f
> (1 row)
> Thus true when the point is inside & false when it isn't, as it should be.
>> Is there a document that specifies this?
> There are two documents that are relevant, the PostGIS docs at www.postgis.org,
> but also the SFS whitepaper at:
> http://www.opengeospatial.org/standards/sfs
> which more fully defines the SFS functions which are implemented by PostGIS.
> Cheers,
>   Brent Wood
> postgis-users mailing list
Michael Welter
Telecom Matters Corp.
Denver, Colorado US
+1.303.414.4980
mike at TelecomMatters.net
www.TelecomMatters.net
