[postgis-users] liblwgeom.dll API?
Obe, Regina robe.dnd at cityofboston.gov
Wed May 2 09:12:51 PDT 2007
Not quite clear what you are trying to do. Are you trying to use the
liblwgeom.dll separate from Postgis/PostGreSQL database?  I don't think
its designed for that.  Probably better off using geos library if that
is your intention.
If you are simply trying to use the postgis spatial functions against a
postgis database, then you should be using NpgSQL postgresql driver.  No
need to directly link to liblwgeom for that.
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
gavin.churcher at bt.com
Sent: Wednesday, May 02, 2007 11:58 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] liblwgeom.dll API?
Hi, I'm looking to call some spatial functions that are contained within
liblwgeom.dll (postgis) from inside my own code (c# / .NET) but can't
quite get the signatures right. Is there an API available (or header
file) that I could use?
Thanks,
Gavin
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
