[postgis-users] Install problem
Brent Wood pcreso at pcreso.com
Wed May 2 12:21:34 PDT 2007
Hopefully someone can point me in the right direction.
I'm trying a Debian based distro (SimplyMepis) & have compiled & installed
Postgres, & am trying to get Postgis working.
(The repositories do not have latest versions, & I'm running 64bit which is not
supported by DebianGIS- hence the compile from source)
Postgres seems fine:
select version();
PostgreSQL 8.2.4 on x86_64-unknown-linux-gnu, compiled by GCC gcc (GCC) 4.0.3
(Ubuntu 4.0.3-1ubuntu5)
PostGIS seemed to configure/make/make install fine.
However, when I try to install Postgis into a database it fails.
createlang plpgsql baw     # seemed fine
psql -d baw -f lwpostgis.sql   # fails, the initial error msg is:
BEGIN
psql:lwpostgis.sql:43: NOTICE:  type "histogram2d" is not yet defined
DETAIL:  Creating a shell type definition.
psql:lwpostgis.sql:43: ERROR:  could not load library
"/usr/local/pgsql/lib/liblwgeom.so.1.2": /usr/local/pgsql/lib/liblwgeom.so.1.2:
undefined symbol: has_arc
psql:lwpostgis.sql:48: ERROR:  current transaction is aborted, commands ignored
until end of transaction block
the library file does exist: /usr/local/pgsql/lib/liblwgeom.so.1.2
ls -l /usr/local/pgsql/lib/liblwgeom.so.1.2
-rwxr-xr-x 1 root root 1371563 2007-05-02 18:50
I tried runing ldconfig to tidy up lib paths,
locate liblwgeom
(the 1st two are symlinks to the last one)
suggests there is no other lib file of thge same name hanging around.
Can anyone suggest what the problem is & how to fix it? I've normally used
OpenSUSE & have not run into this problem before.
Thanks,
   Brent Wood
