[postgis-users] GeomUnion problem
Brent Wood
pcreso at pcreso.com
Mon May 7 20:41:40 PDT 2007
--- Rob Agar <robagar at westnet.com.au> wrote:
> hi Brent
> Would just wrapping the call to GeomUnion with a call to Multi do the trick?
> From the docs:
> Multi(geometry) - Returns the geometry as a MULTI* geometry. If the
> geometry is already a MULTI*, it is returned unchanged.
Thanks Paul & Rob,
That seems absolutely perfect!!!
(I'm running it right now with separate poly & multi columns, so I'll just
update the multi column with the multi(poly) when it finishes....
Much appreciated guys!!!
Cheers,
Brent
