[postgis-users] Best way to return a WKB when using pglib
mateusz at loskot.net mateusz at loskot.net
Wed May 9 01:35:27 PDT 2007
I also use
encode(asbinary(the_geom), 'hex')
which is about 30% bigger in volume but simple and fast in parsing.
Mateusz
Paul Ramsey wrote:
> encode(asbinary(the_geom), 'base64')
> Rob Tester wrote:
>> I am writing an extension (libpg) that ultimately can create several
>> hundred to several thousand WKT polygons. Once I have the WKT created,
>> instead of returning them I would prefer to return the WKB inside the
>> tuple. How can I efficiently return a WKB inside the tuple instead of
>> the WKT?
>> Any help or push in the right direction would be appreciated.
